sounds in wonder ware
RY_Guthrie
Nov 2011
Las vegas, NV
263
Im trying to sound an alarm when a tag value goes below a certain value. I am looking for just the manual that will explain that. Anybody know where i can find this info?
is it possible to just add a little buzzer or something off of a plc output? and trigger it when its below the setpoint
You can do this within script using the StartApp() command. You will find loads of documentation on the Wonderware Developers Network,Go here . I assume you are speaking about Intouch?
The only problem is it will keep the App window open depending on what you used there might be a way to close it in the background after Sound has played. I have not done this before but just opened normal files.
It it a alarm connected to an output? Is it an audio alarm on PC?
We need to integrate sounds in our projects (e.g. when a button is pressed a sound acknowledges the event). The idea is to integrate the above...
2,219
Hello All, Can anyone recommend a panel mounted Alarm Sounder that is not annoying? I am not having much luck asking the Google Machine, so I...
2,198
Hi guys please help me with something, i'm new with factory talk SE and everything about rockwell so let me try to explain it, in my job we have a...
1,317
Hello, As Remote Access is coming more and more popular, I would like to have some opinions from people that use the solutions that are...
6,555
OK I'm really stuck on this one.. I have a 4-20mA signal from a micrologix 1200 going to a AB 1336 drive. The system is on a Army Truck assembly...
5,470
