Egil-s Member E Join Date Jul 2008 Location Norway Posts 18 Oct 23, 2008 #1 Hello. Where do i find special marks for the s7300? By that i mean like: SM0.0 is always ON on the s7200. Thank you.
L D[AR2P#0.0] Lifetime Supporting Member L Join Date Nov 2006 Location UK Posts 6,699 Oct 23, 2008 #2 There aren't any. You control all M flags with your program. (you can copy the plc "flashing" bits to a MB - this is set up in the h/w config for the CPU)
Egil-s Member OP E Join Date Jul 2008 Location Norway Posts 18 Oct 23, 2008 #3 So what would be the easiest way to enable move word?
L D[AR2P#0.0] Lifetime Supporting Member L Join Date Nov 2006 Location UK Posts 6,699 Oct 23, 2008 #4 Why enable it with TRUE ?
Egil-s Member OP E Join Date Jul 2008 Location Norway Posts 18 Oct 23, 2008 #5 Ah ok, though i needed a bit to enable like on the s7200. Well, that cleared everything up Thanks
