Mitsubishi GX Developer Special Relays
Jhona
Oct 2016
Morelos
Hi!!
Could someone please help me find a special relay command (not a real relay) that stays activated when it receives a pulse from a NO contact (X0), and desactivies when it receives a second pulse from the same NO contact (X0)?
I hope you understand me... Help please....
Check out the ALT function
From the manual...
Every time the command input turns ON from OFF the bit device specified is alternated (from ON to OFF or OFF to ON).
Thanks for the info guys! Now I have an other problem... I can't find any info of the ALT command and my HELP opcion on the Gx developer send me to a windows help and that doesn't give nothing :(
I already download some manuals but, as I said theres not much info of the ALT command... Can some give a quick example? PLEASEEEE
Really ? I found this on google in 30 seconds:
ftp://81.105.173.212/PLC/Legacy Product/Fx Series/Fx/INSTRUCTIONS/SAU661A.PDF
PS, you haven't told us which CPU you are using......
Hi One of the PLC's that I maintain/update is a Mitsubishi Q-Series, probably installed about 10 years ago. At the moment, ALL the wires from...
1,176
Hi everyone, I'm working on a Mitsubishi Q series PLC whose code was developed in Mistubishi's GX IEC Developer v7.04. I looked online for GX IEC...
1,488
502
On our system, on the HMI we've got a page of setpoints. These are the values at which alarms are set (e.g. a high temperature alarm or a low...
1,243
On our PLC we've got a HMI where the operator can enter a target rotor speed in RPM. When target speed is enabled, M70 = TRUE. Then the operator...
19
2,835
