geniusintraining
Anyone use them? I bought a couple and I am going to start using them to flash the firmware but since I have a IF2 in slot one and this is the location that the 2080-SDMEMRTC-SC needs to be installed on wondering if I can flash the firmware and load the program then removed the module and put it into run or the only thing I can do is firmware update and not the program? read the manual and it does not state anything that I could see about if you have a module in the first slot and still wanted to use the SC
