Speeding up WinCC flex 2007
Werner
Apr 2005
IJsselstein
336
Hi!
Do you guys have some tips on how to speed up WinCC flexible 2007?
For instance what I would like is to switch of the menu animations. (You can switch it off for XP so you might be able to do the same for WinCC flexible).
Maybe any other tips? All help is welcome...
Work with projects stored on a local drive, not a network drive.
Use a fast HD (RAID 0 = striped disks ?)
2 GB RAM.
Huge monitor, so you dont have to open and close the various sub-windows all the time.
2 GB RAM.
I have project on local drive
I have 2GB Ram
I have laptop (don't know if that is a fast drive)
The huge monitor is lacking...
2 out of 4 is not bad...
Laptop HDs are typically slower than HDs on stationary PCs.
This is the main problem with running Flex on a laptop.
I have 2 PCs, a stationary which is "owned" by the IT department, and a laptop for traving which is "owned" by me. 90% of my programming work is on the stationay PC.
Hey everyone, Working on a project replacing a whole bunch of various AB drives (1336, Powerflex 40 etc) with Powerflex 525s. The motors are 3HP...
3,022
I have an issue with an elevator being driven by a 525 where when the second shelf (of 8 tiers) gets loaded on to the conveyor the drive over...
3,587
We have a powerflex4 drive I am going to over speed or overclock take from 60hz to a 100hz Any reasons you would suggest not doing this I just...
2,194
is there any free trial version available for step7 professional and wincc comfort v17. i searched and downloaded TRIAL Download STEP 7...
80
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
85
