SQL, RSView Question....
just_lionel
Nov 2004
Edenton, NC
323
Hello All,
I have searched and have read many posts until I am a little more than confused.
I need to log data from two separate pieces of equipment that will allow our QA department to view and print records of conveyor speed, temps, level's etc. I need to these variables every fifteen minutes.
I know that excel is out of the question due to its limitations. The equipment is controlled by RSView HMI's (RSview ME). Do I need to set up the ODBC settings through here? Or can I log straight from the PLC and push into SQL Express?
I think I have to do it through RSview, but I want to make sure! Any help would be great!
Thanks guys!
RSView won't help you in the way of SQL data logging. Neither will any AB PLCs. Your options are between a hardware or software data logger.
As a rule of thumb, your hardware data logger is more like an appliance - it should have less potential for failure than the PC (The DB runs on a PLC, so ensure that the device does local caching). Hardware devices tend to be less flexible than their software counterparts. There's a recent thread on X-Coupler, available as a Control Logix module. It's well recieved here.
In contrast, software based data loggers run on a PC, which is usually more flexible and powerful, but less robust. In general, I wouldn't categorize either approach as easier or more difficult to configure. The PC as a platform is obviously something that you should run in a more controlled environment that depends on the network for connectivity. In the Rockwell world you're talking about FactoryTalk Historian. I'd also recommend considering a 3rd party OPC data logging application like FactorySQL.
Thanks guys!
I'm using RSView VBA to record the last parameter adjustments made for a given product in an MS Access data base. The Access table contains...
2,339
I am running RSview SE in a local runtime. I have an alarm history object in a display. When the display is called to open that causes an error...
1,898
I'm wondering if anyone has any suggestions on how best to display SQL data on an RsView screen. As the operator is processing a batch we're...
4,136
Hello, I use an ODBC database in RSView SE 4.00 to log factory talk messages and errors to a sql server 2000 database. But, there is an error in...
4,951
I'm currently trying to Implement a RSView SE app to write to a SQL DB. (MySQL) I have completed setting up the datalog models based on...
13,832
