Square D PM710-Modbus TRU and Wonderware
Apel
Aug 2007
Singapore
98
dear all,
any one know, how to communicate wonderware and Square D pm710 RTU module..this is having only RS485 port with + and - marked.I cant get it how to connect this with my PC side port r+,r-,S+ and S-, with DCE and DTE selection switch.
RTU module setting is addr.=1, baudrate=9600,parity=none,
Holding address starts at 4000.
thanksx
Your PM710 is a 2-wire RS485 device. The PC is a 4-wire device.
Your options are:
Simply wire the PC r+ to the s+ and R- to s- effectively creating a 2-wire connection. Notice this does not always work but I am not aware of it causing any problems. Sometimes a 120 Ohm resistor is needed across the PM710 terminals.
Or, what always works is a 2-wire to 4-wire convertor. You can get these from many places (Square D's is #CNV-100).
One place I used to go for RS485 applications was Robust DataCom at www.robustdc.com.
Square-D Symax SFI-324 I have used the SFI-510 card for many projects, but I came across a SFI-324. Does anyone have ant tech info on it?
85
hi everybody i want to make a backup (upload) from a plc square d micro 1 ready i have the software WINLDR i am looking the cable to Conect to a...
521
Hello guys, I need to understand how instructions work in Square D Symax PLC. I need to upgrade old code which is in Square D symax SCP401...
2,379
840
658
