SSI Encoder problem
dimmarkov
Jan 2009
Sofia
33
I have a problem with Siemens SSI Encoder and module 6ES7 338-4BC01-0AB0 (Siemens), CPU 314C-2DP (6ES7 314-6CF01-0AB0).
People from the factory have changed SSI Encoder, module and the cable.
The only think that is not changed is connector of SSI Encoder.
But problem remains, communications between the module and encoder works for let say 15 minutes and after that stops.
Could you help me with some suggestions?
Hello to all I have a problem with encoder from bei sensors. encoder is dual with ttl and ssi channels. When i turn off and turn on my system...
3,607
Hi Guys I am using SICK absolute encoder ATM 60 with an SSI to Parallel Converter (AD-SSIG-PA) to connect to a Mitsubishi Q02HPLC. The set up...
6,379
Hi all, I have an application coming up where I have a motor that runs forward or backward to adjust the linear position of a machine component...
1,319
I'm being asked to bid a control system using Siemens S7-1500 controllers, which I don't have any experience with. The digital, analog, and...
2,676
Hey Guys, I am trying to use an SSI encoder for the first time and having problems getting any data from it. I am using a 1738-SSIM23 Armorblock...
4,008
