I currently have a RStahl Ethernet Remote I/O which talks Modibus TCP/IP on our network and would like for it to talk to a 1756-ENBT card installed in a chassis with a 1756-L62 processor. I have created a generic Ethernet module within the existing 1756-ENBT card with the settings supplied by RStahl. Input 142/134 8 bit
Output 132/134 8 bit
Config 107/0 8 bit
I can communicate with the RStahl Ethernet Device, using Pactware, and observe the data coming into the Remote I/O. I unfortunately am not sure I cam seeing that same information in the controller tags created within the RSLOGIX program. Has anybody attempted this before and have a solution.
I had the set up the Generic Ethernet Module as a Data-SINT or I get an I/O error. I tried to convert the Data-SINT to a INT data type, but it still doesn't give me the data I was hoping for.
Let me know what other information you might need, as this is generic
Config 107/0 8 bit
