Star Delta Phase sequence
md.abdullah
Sep 2011
motihari
168
Dear all
Is phase sequence in Star Delta starter necessary, Just i got flash with wrong phase sequence.can anyone tell me how to know the phase sequence if i am starting first time???
Type in Star/Delta wiring diagram into google, but if you do not know what you are doing get someone who does, otherwise you may do some serious damage.
the current in delta should have same direction as the star situation.
this is why the connections are not U1,V1,W1 and U2,V2,W2
but V2,W2,U2
so you put L1 on U1 and V2 etc. find a connection diagram and simulate the phases
If you manage to swap a phase when changing, you got a wiring error.. Check your diagrams and consider getting someone who knows what they are doing...
Did you remember to take out the inserts from the termination terminals in the motor?
Did the flash occur when it first started in star or did it occur
as it transferred from star to delta.
Take a photo of the motor terminal box for us to see.
Finding someone who knows about star delta starters and motors
is your best option though.
Is this motor US or EU? Your peckerhead should have a diagram of what pins go to what. I agree with the above post, give us a solid pic of the motor and we can tell you where to land what. You crossed a phase somewhere you shouldn't have :(.
Gyus motor is from Itlay.when i first started it got flash. I checked the connection at TB side there it was burn at V2 and W2.when i changed the V2 to W2 it works.I could not understand why it git flash in first situation???
Hi, We have a project to replace one Star Delta connection for 90kw motor (3 phase, 415V) with an Inverter. Before dismantle the S/D, the current...
10,567
HI EXPERTS SOMEBODY ASKED ME TO CHANGE THE ROATION OF A STAR DELTA 3 PHASE MOTOR HOW THIS IS POSSIBLE ON A REGULAR DIRECT ON LINE STARTING...
11,409
Here's a question I thought I'd never ask with all my 50 years of experience but I don't know - so I'm asking. I have to change a star delta...
23
3,186
Found that a trouble some pumps that kept causing overcurrent faults on the VFDs were wired in star instead of delta configuration. In star...
2,639
Hi all, Got a customer who's asked me to look at a new machine they've gotten in which they're having trouble starting. It's a brand new...
4,306
