start & end bytes? micrologix1500
fusion
Jul 2005
Auckland
26
i am trying to send binary numbers to the plc on I:1/1. How can i tell the plc when to start reading and then stop reading the numbers iam sending.
for eg 200. so i send 2, 0 , 0.. will the plc accept it as BCD, yes. but wat other data functions do i send with 200 to make the plc start and stop reading and not expect anymore input?
And i am sending the most significant bit first, is that correct or do i need to send least significant first?
i read the communication commands and i found the micrologix1000 information on Unprotected Write to plc which looks like this
C = |DST|SRC|CMD08|STS| TNS |ADDRESS LOW|ADDRESS HIGH| DATA |
R = |SRC|DST|CMD48|STS| TNS |
What excatly does that mean?
First, you should have continued the previous thread you started, instead of starting a new one. Lancie1 gave you a possible solution in that thread.
Now you cannot send a value greater than 1 to a bit address: I:1/1, you will have to use a word address: I:1.0
Take a look at this Thread on another forum.
Hello! We are using a ControlLogix 1756-L72 PLC with two identical servo motors running separate conveyor belts. The machine this is on runs...
969
HI I AM KOREAN INTOUCH BEGINNER I DO NOT SPEAK ENGLISH WELL. BUT, I'LL WANT INTOUCH 16 PENTREND (HISTORICAL), Start Time And End Time Change...
1,953
Hello With my background in programming and web development a friend came to me for help building a SCADA system, but I'm a newcomer to HMIs...
1,522
Hi, Can anyone tell me how to change the Start time and span of trend via tag using vb in factory talk view se.
3,889
Hello all, I am currently trying to program a PowerFlex 525, version 7.0. We had a power outage recently and when the power was restored, the...
297
