StartApp Function in Wonderware
Ones_Zeros
Feb 2014
at work
367
Hey Guys
I have a batch file that reboots a remote computer
& I use the "StartApp" function in Wonderware to run the
batch file when a button is pressed.
This works fine but what i would like to do is set a message that would pop up asking "Are You Sure" when the reboot button is pressed. I would rather not apply security to the tag.
When i configure the Touch PushButton "Action" script, is there a way to add
a message that pops up asking the user are they sure they want to reboot the computer, then the user would select Yes or No
Thanks,
Instead of making the reboot button run the script, make it open a display, with an "are you sure?" message and a confirm and cancel button. Confirm button runs the script, cancel button closes the popup.
No worries. Yes, I meant to have the button display a new popup window - I don't do enough Wonderware to know the commands of the top of my head, but it sounds like you're all over it. Glad you got it working!
Hi, I have attached herewith one image which our programmer has been used in S7 1500 PLC. Now we need to use the same instructions in S7 1200 PLC...
123
Im trying to create a level indicator for water Tank i have used the ADD function while the pump is on and level increasing everything works...
33
1,084
Good morning crew! Ok my logic works but I am missing something. When the start button is pushed it should like the red light for 4sec then shut...
427
Please see attached file. I need this program in Function Block form but I am totally lost on this. Any help would be appreciated. Thanks!
303
The idea here is to provide for a brief rapid influx of message codes while preventing sequentially repeating the same message. i.e. if two...
23
696
