Status bits needed before MSO, Kinetix 5500, 5700
Kaurk
Mar 2015
Estonia
Hi everybody,
What are the suggested status bits of servo axes before starting MSO that will ensure a MSO activation without ER.
My current setup is attached as picture.
Something is still missing because MSO still can give ER signal.
What i Check:
Fault statuses
GroupSynced
BusUpStatus
And a delay for good measure.
Kaur
Whats the reasoning? Thats a user or program input that is low most of the time and at start up.
Im leaning towards some status bit that is still missing. So the MSO command comes too soon and faults out.
Do you still have the image of your logic. I also am looking for the conditions needed before an MSO on Kinetix 5700
faults
physical axis faults
module fault
config fault
group fault
motor fault
statuses
no estops
no shutdown in progress on servo
no drive enabled status
no start request
delay can be up to 3 secs I suppose or trimmed down to 1 sec.
I'm losing it...I accidentally posted this in a existing thread thinking I was starting a new thread. Time to put me out to pasture. Instead of...
1,235
Upon adding the OB16 module in CCW, i see that it shows that it has status bits (assuming one for each output, (IO_X2_ST_00, IO_X2_ST_01, etc)). I...
683
This is in an existing application, so stuff I've found and I'm trying to debug. I've got no Tech support contract, so can't view Tech Notes :/...
1,592
Hey everyone, Currently working on a project to replace some old AB 1336 and PowerFlex 4 drives with 525s, as well as the existing SLC 5/04 with...
5,843
Hello guys, I want to add a few status bits to the HMI program for the operator. There are 5-AB 1769 L32E Compact Logix PLC's throughout the...
3,785
