Step 5 comms probs
kevbloke
Jul 2004
Kent uk
81
Hello,
I have a problem with getting communication with any step5 plc with my new Dell Latitude D630.
We used to have a nice Field PG but that died and was replaced by them with tight purses with the latitude. This unit is working with step7, Gx developer, pro-tool, E-designer and many others but not with step5.
Any ideas please step5 guru's
Kev
kevbloke said:
Hello,
Kev
I use DosBox http://www.dosbox.com/ and Step 5 with my Latitude with no issues
One things you need to know the communication port on S5 is a TTY port, it is not RS232. you need a convertor then your laptop can talking with S5
Cheers guys
The problem turned out to be that the markem connectivity option had been selected to "start" in the services. This hijacks the comm port.I have now set this to "stop". I can now go online.
Thanks for the input guys, you have still given me some good links that i didn't know about.
Kev
Hi. I've got: CPU 317-2 DP / 6ES7 317-2AK14-0AB0 CP 342-5 / 6GK7 342-5DA03-0XE0 CP 343-1 / 6GK7 343-1EX30-0XE0 Basically S7 gathers a lot of...
2,619
Morning all I have a profinet network with a combination of S7-315s and an S7-200. One of the 315s has been coded in TIA portal, the others in...
3,261
hi I am involved in a project that will be using a siemens CPU315-2PN/DP processor, I am conversent with plcs but unfortunatly I have not had a...
4,456
Quick question guys. Never work on step 5 b4 but wanna know if u can get comms with usb port and Windows 98. It's a U-100... I think.
1,942
Hellllllpppppppp! :eek: I have a small problem with Step 7 V5.2 and native tcp/ip comms. Can anyone tell me a decent way to set up native tcp/ip...
7,037
