Anyone seen this before? While monitoring networks with a particular FC call, I see this in the status bar: "PLC data invalid"; it doesn't show any data.
Other networks in the calling FC can be monitored fine, just the ones with that particular FC call can't be monitored. I am able to monitor the variables via the Address Info tab fine. The FC in question has an elaborate interface, there are some 50 tags.
This is Step 7 5.5, CPU is a 319. This FC's interface is quite elaborate, about 50 or so tags. Monitoring has never been an issue until now. It does the same on a different engineering station. However, monitoring is not an issue on a different system that uses a 318.
