Step 7 Symbol Update Procedure
hdbishopjr
Aug 2009
Indiana
I have a PLC with a German Symbol file. I created a english one that is identical to the german one except its in english. I deleted the german one and am trying to figure how to get my ladder to reflect the english symbol file. When I slide my mouse over a contact symbol, the german description is still there. Does anyone know the correct procedure to update a symbol file, or replace it. All the symbol names are the same, the only difference is the descriptions.
Dave
STEP7 and not STEP7 Microwin I presume ?
In which "symbol file" did you make the changes ? In a STEP7 project there can only be one symbol file per CPU (The "Symbols" in the project tree).
If you exported the symbols to a .DIF file, and made your edits in the .DIF file you must import them to update the active symbols.
step 7 sp4
I have two symbol files. If I export them; they are called AAAAAAAA.asc and I can import and export them all day long but it deosnt seem to affect anything.
Where is the symbol table stored? it needs to be within the CPU tree. If its a folder not within a CPU then it wont affect any of the blocks within that CPU
Is there a way to convert or export Step 7 Symbol table to RSlogix 5000 Program Tags
5,527
hi. i want to use symbol table of S7 project in wincc with "STEP 7 Symbol Server". but i don't know how it is work. please hlep me. Honar
2,618
Hi, Added a new station to an existing project. Programmed it, using symbols etc, looked real nice. Machine also needs a HMI, so I added one...
7,285
Hello, I'm afraid I need your help again. I have STEP 7 project and installed WinCC 6.0 demo. I manage to make a simple visualisation system. I...
19,445
Help! Any body out there could figure me out how can I change previously defined symbol on Step7 Microwin32. For example, I defined I0.4 as low...
2,120
