Step 7/Win CC, Can't attach database to SQL server.
AutomationTechBrian
Jul 2013
St. Cloud, MN
669
I'm trying to use a copy of my (new) customer's Siemens Step 7 project files to further my knowledge of Step 7. I archived his project files today and tried retrieving them tonight, but I get this window when I try to open up the screens in WinCC. I don't know why I would get this, or how I address it. I thought if you archive the project it would include all of the applicable project details. Any ideas?
The path and folder names sound more like WinCC Flexible.
Can you expand the project folder in Simatic Manager and do a screenshot?
Or right click the project in Simatic Manager and go to properties and let’s see what software is used in the project
There’s much to learn grasshopper haha
You sure your not trying to open a newer project with an older version of WinCC Flexible?
Also let’s see what the project uses and what you have installed
From Simatic Manager go to help then installed software
Am I sure....? Well, I was hoping I could still open the 5.6 with my 5.5... at least to explore. I knew there might be a snag, but didn't expect this.
5.6 is Windows 7... probably 64bit. 5.5 is XP and 32bit.
....dang!
I'll check WinCC. I suspect the same thing.
Don’t confuse Step 7 with WinCC Flex
They are different
Step7 is for plc programming and Simatic Manager is the framework
WinCC Flexible is for the hmi portion. WinCC Flexible does use a cut down version of sql.
They are different
Right, I knew this. Just like "Starter" is used if you click on the drives.
I had my fingers crossed that I could open the screens and see how the addressing occurs... versus AB and Red Lion.
5.5 was a free upgrade from 5.4. I don't expect 5.6 would be free... thoughts?
Good Morning, Hoping someone with some Siemens experience can give me a hand with this one. Customer has a S7-200 cpu, which has a 6GK7...
251
Good day we have a very old software project that was downloaded to a S7-200 plc We have bought the Micro/win v4 software so that we can try...
22
5,383
I have only ever had to work with rockwell software and I have 0 experience with siemens software. The place I work at now has seimens software...
2,119
Hi, I recently got a laptop to install Step 7 MicroWIN on, its a Windows 7 laptop 64-bit. I have moved the .exe files for the full installation...
4,676
Hello everybody' I am newer. I use position control wizard in tool to get some subroutines. but I don't know the input and output parametes...
1,698
