Step7 error code when using Retrieve command
Sandman67
Aug 2005
Florida
Hello everyone,
This is my first post and has to do with using the Retrieve command in Step7 Simatic Manager. A vendor recently sent us an updated program in a zipped file and told us to use Retrieve to extract it. The problem is when I do this it will halt and then a message appears: Archive program terminated itself with exit code 199. Does anyone out there know what this means? I have sent an e-mail back to the vendor but getting information from them is sometimes like pulling teeth. Thanks in advance for any help on this.
msanders
Try to use PKZIP or WinZip to extract the archive file.
If everything opens OK, then you know that zip file is OK.
Also, you can open the unzipped project files by just pointing STEP7 to the directory where you unzipped the files (using "File..Open", not "Retieve").
Hello, When trying to enable the Operator Control & Monitoring features in Data blocks of the Step 7 5.7 project it gives the Error of Operator...
921
While trying to download an FC to a Siemens plc CPU315-2DP , we are getting the following error . What does it mean ? How to solve this problem ...
3,125
Hello, I have some question regardering step7 diagnostick buffer. Please see attached screenshoot, why does I have error on the CPU when I`dont...
2,074
I have install the software step7. I i want to open blocks example ob1,ob2.... It is not possible i get message An internal error ocurrend 256:26...
2,260
What can casue this error (DO63)Resource Error)? Thank you for answering!
2,977
