Step7 online to CPU314 via ethernet
shandra_ck
Jan 2005
Malaysia
63
Hi all,
I am having problem to go online to CPU 314 via ethernet. There is a CP 343-1 attached to this cpu.
I am working with a PC running on windows 2000 SP 2, Step 7 version 5.1 SP 2.
I would like to go online to cpu 314 via ethernet.
I am not sure the exact software to use. I tried with
the NCM S7 industrial ethernet V5.1 SP2 and
IE Sofnet V3.3 but unable to go online.
Do I have to set anything on NetPro?
Please guide.
Thank you.
Regards,
Shandra
Online to CPU300 via ethernet
Hi guys,
I actually working on a pc that was crashed. This pc was used to go online
to the cpu from Step 7 for troubleshooting purpose.
The softwares that was installed earlier was
IE Softnet S7 3.3
NCM S7 Industrial Ethernet V5.1 SP3
NCM S7 Profibus V5.1 SP3
Simatic Net S7/SR OPC server 2.2
Step 7 Version 5.1 SP 4
My current software installed is as mention below:
Hardware
S7300
CP 314-1
IE Softnet S7 3.3
NCM S7 Industrial Ethernet V5.1 SP3 +hotfix 1
NCM S7 Profibus V5.1 SP3 hotfix 1
Step 7 Version 5.1 + SP 6
I already set the NCM S7 Industrial ethernet V5.1 SP 3 + Hotfix 1 and
configure the ethernet (Ip address).
Can anyone guide me on software setting.
I did go through the manual and it seems that there are a few ways of setting. With the
above softwares can you tell me the sequence of the configuration. (What softwares must be configured?)
So far I only configure NCM S7 industrial ethernet with the IPs and all
according to the manual but when I go online The message stated that
Window title : Display Accessible node
This function is not supported by the online interface that is set.
PG/PC Setting : TCP/IP -> Broadcom 440x 10/100 and its working fine. (I am using normal Ethenet card)
Previosly this pc was configured with standard ethernet card to go online.
Do I have to add this pc to the netpro to the ethernet? Do I have to set the
OPC server?
I really appreciate if someone can help me on this. I need to set up the pc urgently.
Regards,
Shandra
Maybe you can upgrade STEP7. From v5.2 and up there is integral ethernet support in STEP7 with no need for Simatic Net software.
With Simatic Net software it is also possible to get STEP7 online with ethernet. Unfortunately I have never tried it myself. I believe you have to set up a socalled "PG/PC station".
Not sure how that works with v3.3 of Simatic Net. The latest version is Simatic Softnet "2005", and the one before that was "v6.3" so your software is a bit old I'm afraid.
Hello Experts, How can i update my offline Data Block to the Online Datablock without removing the offline comments? When i go online with the...
3,596
Hello forum citizens! Let me know, please, what way to watch FB which uses different instances of DB in the monitoring mode (STEP7 v.5.5) ? I...
1,801
Hi everyone! I have a question for the Siemens Step7 gurus out there. But first, some background! There's also a TL;DR at bottom if you don't...
5,979
Hello to all members of this thread, I've been trying to compare siemens step7 project online and offline block comparison in ladder. when I click...
6,080
Hi, This may be one of those questions which has a glaringly obvious answer but it escapes me entirely... I have two projects open [offline] in...
8,612
