Step7 - problem translating from STL to FB
RMA
Sep 2004
North of Hamburg, Germany
2,052
The following code snippet is part of a longer STL Network monitoring the press-fitting of a bearing. The error condition gets set if the timer times out.
Code:
	 A	 "St1.5_DB Handling".N12
	 AN(
	 AN	"ME_MW-1.5S05.01"
	 A(
	 A	 "ME_MW-1.5S05.02"
	 A	 "ME_MW-1.5S06.01"
	 O
	 A	 "ME_MW-1.5S05.04"
	 AN	"ME_MW-1.5S06.01"
	 L	 S5T#4S
	 SD	"T84"					 //Überwachungszeit, danach wird Teil NIO gesetzt
In order to better understand what exactly is going on, I wanted to convert it to FB, which I'm more comfortable with for this sort of thing. However, try as I might, I can't get it to come up with an identical listing when I convert my FB version back to STL.
This was pretty well my nearest approach so far (I replaced the Timer with M1000.0 for test purposes):
When I convert it back to STL I got the following:
Code:
	 A(
	 A(
	 A	 "ME_MW-1.5S05.02"
	 A	 "ME_MW-1.5S06.01"
	 O
	 A	 "ME_MW-1.5S05.04"
	 NOT
	 =	 M 1000.0
which is not quite right. Had the final "NOT" been after the second closing bracket, I might have accepted it as being equivalent, but not where it is.
If I try moving the negation to immediately before the assign command (=) in the FB instead of on the preceding &-input, the the outer bracket pair disappears completely, which is also not quite right! o_O
Would anybody like to have a go at producing an FB (or Ladder) version of the commands which translates exactly to the first version.
Edit:I managed to post this twice, where do I find the "delete Thread option?
The following code snippet is part of a longer STL Network monitoring the press-fitting of a bearing. The error condition gets set if the timer...
3,990
I am trying to check what is the value coming from the pot and depending on the value change the value inside the DB11.DBD0 But it is not working...
24
3,335
Dear all, I don't know why the above section (written in SCL) switches the CPU to stop mode. When I delete the two lines highlighted with...
2,903
I have a problem and i can't resolve it. I want to configure some connection beetween plc's,hmi's etc but whenever I try tu run the NetPro using...
6,103
Hi All, I'm trying to install STEP7 V5.4 on a system which is having Windows XP proffesional.I'm getting the message as below.... "There are...
4,393
