Step7 Variable Names
kamenges
Nov 2002
Green Bay, WI
4,332
I have a Siemens project coming up where we will be using Step7 V5.5. Jeebs made a comment in this thread that got me thinking about my future.
The last time I used Step7, there was no way to upload a block that had a timestamp mismatch and still maintain the variable name declarations or block internal variables. Is that still the case or has that changed? To the best of my knowledge the only ways to get out of that case are to:
1 Download the offline copy and hope the differences are minor enough not to cause an issue
2 Upload the offline copy and lose the variable names
3 Do an offline to online compare, modify the offline block to match the important online status and download the new offline block.
Does that about sum it up or am I missing something?
Keith
The new STEP7 v11 has a new feature to upload the online actual values.
But it is not perfect at all. You may have to do a lot of copy-and-paste between the uploaded actual values and the offline actual values. We can only hope that Siemens one day finally listens to its customers and gives us the one-button upload of all actual values that we want.
Thanks guys. I was hoping I was missing somehting since I haven't done any serious Siemens work for about 8 years. But alas...
I just need to be careful with my online/offline correlation I guess.
Hi everyone, I hope you can help me. Im working with get the production parts of all hours-day using STL. My idea is to use an array [0..23] of...
3,853
Hello! Is it possible to copy pointer's pointing address to any variable at Siemens step7? I mean I have pointer address to db block with...
15,612
Hi! I am new to Siemens Step7 and are hoping for some little starthelp, Thanks. I have made some FB, but would like to know if it is possible...
7,539
is there any free trial version available for step7 professional and wincc comfort v17. i searched and downloaded TRIAL Download STEP 7...
65
Hello. I need your help. I work at STEP7. There are two CPU 317-2 PN/DP controllers (317-2EK14-0AB0), working on PROFIBUS, as Master (CPU_1) and...
175
