Stepper Motor Driver Vs. Solid State Relays
ming0521
Dec 2011
Ohio
What are the pros and cons of using stepper motor driver over SSRs in running a typical stepper motor?
Thanks! =))
SSR's are the wrong choice for many reasons.
They weren't built for stepper motors.
Large, expensive, slow.
I'm a bit surprised. Why would you even consider SSR's as a choice?
A Stepper driver is controlling the current and not the Voltage.
An SSR is just On/off however cheaper and yes it works but you can not get the max out of the motor like stepping speed and torque.
i am planning to use SSR, since it's just a training module / trainer, it's for my thesis... But i already have both, so my team mates decided to use both as control modes in running the stepper motor... but we need to make a comparison... our plc is siemens S7200 CPU 212, we alredy have a program for SSR, but none for stepper motor yet..
Hello. I am using the following: Eaton E4-AC-12RXP PLC I am trying to control the CL86T which controls a Closed-Loop Stepper motor. I am using...
976
Hello everyone, It's been a while I haven't dive into PLC programming (more than 5 years) and I wasn't doing it alot as programmer. I am now...
1,841
A few days back I posted that you can use a PLC as a Stepper Motor Driver. I got mixed reactions and a lot of requests to see it. So, I posted a...
3,604
Hello PLCTalk friends, I have a question about stepper motors and drivers. I will likely have to be setting up steppers at work to control a...
4,282
Hi folks, I'm a newbie here and I have a question that I have been trying hard to find an answer. Currently I have a Keyence plc (transistor...
11,784
