STL simplify some code
userxyz
May 2002
any
2,768
I need to trend some data in WinCC, so I wrote this:
A M 69.0
JC HI
L 0
T MW 100
JC end
HI: L 1
T MW 100
end: NOP 0
Can this be simplified ? As allways, I want to learn to write shorter and shorter
Is it a good manner to trend this in WinCC ?
Combo,
I don't see the need for even a single line of code in the PLC program when I want to trend data in a SCADA system. I don't use WinCC myself because I'm kind of a Citect addict when it comes to SCADA, but I'm sure WinCC can trend a boolean variable as well as Citect can do it.
The only way you really need PLC code for the SCADA system is when you're packing data into a single consistent block to optimise the datatransfer.
Kind regards,
Hi
I had some problems for monitorring a boolean, but what you're saying is true, I had some adressing mistakes.
Hi, I have written something is STL. In STL I'm a little beginner, so maybe, u guys can give some tips how to simplify my code or write it in...
7,207
i am new to simatic manager and i am trying to figure what this part do in the code : A I 5.6 = DB50.DBX 4.6...
144
Hello everyone, can anyone help me with covert the STL code to ladder. Iam using plc s71200. A %DB1.DBX33.7 // angel of vaccum...
226
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
361
First off thank you in advance. Second I am very new to STL. I am trying to build a counter that has one count up and 23 count down options. Am...
396
