Strange behaviour - System Data compare S7
uptown47
Feb 2008
Over there, next to those boxes
1,146
Hi all,
I need to change an IP address on a CPU and wanted to check the hardware config was correct. I compared the 'System Data' in the blocks folder but had an error regarding "the system parameter data of the module in rack 0 slot 5 do not match" (there's a CP341 card in slot 5).
So then I created a brand new project and did a full Upload PG to PC. Then a compare and it showed no differences but warned me that hardware config had not been compiled. I compiled the uploaded hardware config and did a System Data compare and still had errors?
I always thought a Upload PG to PC draws everything out of the CPU including the full h/ware config (obviously without network titles / symbols etc).
Is this not the case?
Or is the compare 'system data' a bit flakey?
Any ideas?
Many thanks ;-)
Hi All, I am using a Red Lion graphite G12 panel to draw a scatter graph, all works well until I run this code every morning to reset the arrays...
19
6,313
Hello, I have several plastic-sleeved roller conveyors in series, all driven by the AB PF525's. Most of the conveyors are straight, except for...
34
12,968
Hi guys this is my first post on this forum but I have been a long time browser. I have this issue with a micrologix 1500, it's a strange one...
2,101
Hi, I replaced a PC on one of our machines yesterday. The existing PC had 2 RS232 ports on a half-height expansion card. The ports were...
1,305
Does anyone have any experience with the Ultra3000 using the Ilimit, we have an application where we are replacing a 1398 with an Ultra and are...
3,320
