String copy in Step7 SCL by SFC20 problems
Coralreef
May 2006
Dk
23
Hi
Im trying to use SFC20 BLK Move in a piece of SCL code in Step7.
I need to copy/move one string[16] in a DB to another DB place !
If a block call is inserted with SFC20 in my SCL code it looks like this :
BLKMOV(SRCBLK := // IN: ANY
,DSTBLK := // OUT: ANY
); // INT
At SRCBLK i would write P#db2000.dbx220.0 BYTE 18 and at DSTBLK i would write P#db2000.dbx20.0 BYTE 18
But this dosnt work ?
I have also tryed doing the call like this :
BLK_Move_Dummy := BLKMOV(SRCBLK := P#db2000.dbx220.0 BYTE 18, DSTBLK := P#db2000.dbx20.0 BYTE 18);
Where BLK_Move_Dummy is defined as an INT for the RET_VAL !
If i do a blk mov with just INT values its all good but as soon as p# pointer for string values are added it all goes wrong. I can do the same pointer in ladder and it works
Here's an example copy using SFC20:
Code:
FUNCTION FC111: void
VAR_TEMP
Source,Dest:ANY;
S AT Source:STRUCT
	TYP:BYTE;
	NUM:INT;
	DBN:INT;
	PTR:DWORD;
	END_STRUCT;
D AT Dest:STRUCT
	TYP:BYTE;
	NUM:INT;
	DBN:INT;
	PTR:DWORD;
	END_STRUCT;
  iSFC20Return:INT;
END_VAR
S.ID:=16#10;
S.TYP:=16#02;
S.NUM:=18;
S.DBN:=2000;
S.PTR:=16#840006e0; //DBX220.0
D.ID:=16#10;
D.TYP:=16#02;
D.NUM:=18;
D.DBN:=2000;
D.PTR:=16#840000A0; //DBX20.0
iSFC20Return:=sfc20(srcblk:= source, dstblk:= dest);
END_FUNCTION
quick and dirty - take the byte address and multiply by 8 and enter the value in hex. The 84 means DBX
Edit - embarrassed mode on
I truely am sleeping this morning.....
Thanks for the basics !
Edit - embarrassed mode off :D
Guys guys ...
Strings and SCL are like fish and water.
No need to program BLKMOV (if BLKMOV is needed, the SCL compiler automatically inserts it in the generated STL code).
Code:
DATA_BLOCK Strings
    STRUCT
        line1 : STRING[20] ;
        line2 : STRING[20] ;
        manylines1 : ARRAY[1..10] OF STRING[20] ;
        manylines2 : ARRAY[1..10] OF STRING[20] ;
    END_STRUCT
BEGIN
    line1:='hello' ;
    line2:='goodbye' ;
    manylines1[1]:='1' ;
    manylines1[2]:='2' ;
    manylines1[3]:='3' ;
    manylines1[4]:='4' ;
    manylines1[5]:='5' ;
    manylines1[6]:='6' ;
    manylines1[7]:='7' ;
    manylines2[2]:='20' ;
END_DATA_BLOCK
FUNCTION String_manipluate : VOID
    "Strings".manylines1[2] := "Strings".line1 ;
    "Strings".line2 := "Strings".line1 ;
    "Strings".Manylines2 := "Strings".Manylines1 ;
END_FUNCTION
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
140
There must be a way to create a 'String Copy' function in Step7, something like: Call FCx FromStr:=SourceString ToStr:=DestString or am I...
5,186
I feel like I'm going crazy, new to Siemens, coming from AB, and I cannot get a dang string copied in SCL. This is a S7-300, V16 PLC. I have a...
3,522
HI Guys So i am trying to write a real SINt or DINT value into a string tag. If in string browser I write it manually, no problem. But how can I...
5,967
I am using v14 with a 1215 dc/dc/dc. I need to copy a 50 element array of strings to another 50 element array of strings. I can work it out for...
4,066
