String to Word Conversion (Codesys)
EnterDownload
May 2015
NY
Hello All
Im using a FESTO PLC with Codesys.
I have a string, named "Program1", which Im trying to convert to a datatype of Word.
Im not sure if the convert function WString_To_Word is the correct function I should be using. When I use WString_to_Word function,
e.g. myTestWord := WString_to_Word("Program1"), I get an output of "0" for myTestWord
myTestWord is a Word data type.
Can someone tell me what Im doing wrong? and how to fix this so that I may get the Word representation of the String ("Program1")?
thanks very much
J
SOLVED : String to Word Conversion
Thanks for pointing me in the right direction danatomega!
VAR
text : STRING[5]:='hello';
char : ARRAY[0..5] OF BYTE;
PT : POINTER TO BYTE;
i : INT;
WordIndex: INT;
ProgramWord: ARRAY[1..5] OF Word;
characterbyteindex: INT;
ProgramWordIndex: INT;
END_VAR
(* This program will take a String and convert it to a Word Data type *)
(* Start by separating the characters from the string into an array *)
pt:=ADR(text); // Get the Address of the text variable named 'hello'
FOR i:=0 TO 4 DO
char:=pt^; // Assign the value of the pointer to a Character
pt:=pt+1; // Advance to the next pointer
END_FOR
characterbyteindex:=1;
(* "hello" has 5 characters...2 characters per word, 3 Words *)
FOR ProgramWordIndex:=1 TO 3 DO // The program name can take up to 3 words
//Get 2 bytes at a time, and store the 2 bytes into a word array,
//e.g. BYTE_TO_WORD char[1], BYTE_TO_WORD char[0], BYTE_TO_WORD char[3], BYTE_TO_WORD char[2], ect.
ProgramWord[ProgramWordIndex]:= SHL(BYTE_TO_WORD(char[characterbyteindex]),8)+BYTE_TO_WORD(char[characterbyteindex-1]);
//Advance the index, to get the next 2 bytes
characterbyteindex:=characterbyteindex+2;
END_FOR // ProgramWord will be a collection of words representing the original string
FactoryTalk ME- Using a"String Input Enable" for Password Entry.How can I place X's Good Morning , FactoryTalk View ME ...... I'm...
2,678
I'm using FTView SE and I'm looking for a way to get my string display to not cut off mid word for my descriptions on my motor faceplates. Some...
2,849
Hello I'm intermediate programmer who is wondering if somebody is able to point me in the right direction in getting a few values in a readable...
17
7,520
Hello, I am using studio 5000 pro and am trying to figure out the structured text. Here's my scenario: An operator scans a barcode, the barcode...
255
I am creating a global object in FTView SE 13. I want to have a string read from the PLC and display (in this case the tagname). So lets say...
174
