Structured Text repeating timer based on true/false bit
spatricks
Jan 2013
oklahoma city
How would I make a timer that would repeat on an interval as long as a certain value is true.
IF EVENT THEN
EVENTXBIT := TRUE
ENDIF
IF EVENTXBIT = TRUE THEN
DO THIS
WAIT X MINUTES
END_IF
IF ANOTHER EVENT THEN
EVENTXBIT := FALSE
ENDIF
This is what I have so far. It counts up to 3 min and then stops, instead of resetting. I figured since I change the variable to false it should retrigger.
Code:
TEST_VAR := TRUE;
TIMER_RETRIGGER_ALM0(TEST_VAR,T#3m);
IF TIMER_RETRIGGER_ALM0.Q THEN
	TEST_VAR  := FALSE;
END_IF;
TEST_VAR := TRUE;
IF TIMER_RETRIGGER_ALM0.Q THEN TEST_VAR := FALSE;
END_IF;
The timer is always called with a TRUE signal and does not 'know' the signal shift.
Try to add the cursive line and see if that works.
The output (.Q) will likely reset also, so you will not be able to catch it outside this code without copying it to another variable.
Kalle
This is how I would do it. Note that this is CoDeSys and it looks like the timer call is a little different than what you are using.
To have something to do each time the timer times out, I just incremented a variable. The thing you want to happen at each timeout should go in the IF/THEN block where I'm incrementing the i variable.
I don't like calling the timer in multiple places as if they get spread out, it can be very difficult to troubleshoot.
Code:
PROGRAM PLC_PRG
VAR
    I: INT;
    FirstPassDone: BOOL;
    Timer_Retrigger_ALM0: TON;
    TEST_VAR: BOOL;
    ALM0_Trigger: BOOL;
END_VAR
(* Run Code on First Pass through Program *)
IF NOT(FirstPassDone) THEN
    I:=0;
    FirstPassDone := TRUE;
END_IF
(* Call the Timer *)
Timer_Retrigger_ALM0(IN:= ALM0_Trigger , PT:= T#5s);
(* Set the Timer Trigger *)
ALM0_Trigger := (TEST_VAR AND NOT(Timer_Retrigger_ALM0.Q));
(* Do Something each time the timer finishes *)
IF Timer_Retrigger_ALM0.Q THEN
    i := i + 1;
END_IF
This is what I figured out before seeing your responses. Let me know what you think. Basically if the ACK bit is the conditional variable.
Code:
TIMER_RETRIGGER_ALM0(NOT TIMER_RETRIGGER_ALM0.Q AND ALM0_ACK,T#2m);
IF TIMER_RETRIGGER_ALM0.Q = TRUE THEN
	 DATA_inputONOFFSMSText := '';
   	 DATA_inputONOFFSMSText := 'Alarm detected: Input 1 is ON';
  	 UTIL_SEND_SMS_2( TRUE, CONFIG_slotID, CONFIG_receiverList, DATA_inputONOFFSMSText);
END_IF;
TEST_VAR := TRUE; TIMER_RETRIGGER_ALM0(TEST_VAR,T#3m); (* after 3m Q will be high always. IF TIMER_RETRIGGER_ALM0.Q THEN TEST_VAR := FALSE; END_IF;
In codesys you can not wait (all plc cant)
but you can use an AND if timer not expired and input true then do your thing.
Hello, I am using studio 5000 pro and am trying to figure out the structured text. Here's my scenario: An operator scans a barcode, the barcode...
280
I have an expression in a structured text routine of a Logix controller that looks more or less like the following: ResultInteger := Integer1 *...
413
Good evening. I display the step number of a SFC on a display. Sometimes, on a trip, it goes quickly through many steps and I need to prove to...
147
I am trying to set up a piece of equipment with a Horner HE-X4R. I'd like to use structured text and so far I'm just trying to get a basic On/off...
80
Good morning. I'm doing a rehab and I need to recycle some part of the old code that won't change and that I need. This is a calculation that...
22
1,380
