structuring programmes
ralph9871
Feb 2010
south yorkshire
Hi I am brand new to plc programming and have just started an on line course. I am currently struggling with a motor control question using increment and decrement values to a data register.Apart from the speed control I do not understand the concept of structuring programmes.Any help in as basic as possible terms would be gratefully accepted.Cheers Ralph
Post the question verbatim.
ok found it:
[FONT=&quot]1. FINE CONTROL - Inc and Dec the speed value on every press of the button. Changing speed say from 1RPM to 2RPM etc[/FONT]​
[FONT=&quot]2. MEDIUM CONTROL – If the operator holds the button pressed for 3seconds then automatically change the speed up or down. Changing 1RPM to 100RPM[/FONT]​
[FONT=&quot]3. COARSE COUNTROL – If the operator holds the button pressed for 15seconds then automatically change the speed up or down as fast as possible. Changing 1RPM to 2000RPM[/FONT]​
Interesting question in that if you are at 1rpm and press the increment button the speed will increase to 2rpm so it will not be possible to use the medium to increase from 1rpm to 100rpm
Should medium increment by 99rpm or 98rpm ?
Similar argument for coarse.
What programming language are you using ?
One way of implementing Structured programming is to use
If....
Then...
Else...
endif
case statemnts
while...
do...
endwhile
Goto or Jump should not be used.
Does this help ?
... so we are talking about structuring a ladder logic program.
I'm not aware of any formal rules for this, anyone else ?
Thanks LD and Mordred for your positive replies, i found them most helpful.
Many thanks to Ozee for your positive comment, not, of "We won't do your homework for you. Ask a specific question."
If you had read the post before it asked me to post the question which i did!! Again many thanks for being so supportive!
I'm refactoring a task handling system that creates transport tasks to shuttle wagons in a material handling system. My environment is S7...
3,169
Hi! I'm a little intrested in how you guys structure your TIA portal projects. We mainly have s7-1200 CPUs in single machines and no...
3,734
Hi I'm after some suggestions. When programming an SLC, I like to structure data tables as follows: LAD 5 Binary B53:xx Timers T54:xx Integers...
2,908
Hi All, I would like to compare 2 s7-200 programmes. Can I do this with microwin or with TIA portal? Does anyone know whereI can get a manual...
3,466
Hello my name is NAGESH . Recently ijoined PLC PROGRAMMING COMPANY. SO i want practice more ladder logic programmes. any one knows...
4,024
