Struthers-Dunn PLC (ca 1977) any help?
onavi
Apr 2004
hello
I have inherited a (USED) barber-colman hobbing machine
It was sent up here from a sister company.
The majority of the schematics are missing.
It has a Struthers-Dunn inc. PLC
Model 75415 Serial# 11191 S-D77 controller
and S-D 64 expander.(probably ca 1977)
I have the statement list for the plc program
and a list of inputs & outputs.
I cannot get the sequence of operation behond a certain point
and not having the ladder schematic I am unable (as yet)
to get to the bottom of this.
I have some familiarity with Omron PLC instruction set
but I am unfamiliar with the Stuthers-Dunn.
Could some one kindly give me an idea of the
meaning of the intructions?
HERE THEY ARE:
(the first column is the instruction
the second is the address)
CMR (NO ADDRESS GIVEN) FIRST INSTRUCTION
CEN (NO ADDRESS GIVEN) SECOND INSTRUCTION
LDA 024
ORC 024
STO 025
OR 001
AND 105
LDAC 057
MR 000
ANDC 105
CMR 000 (ADDRESS GIVEN IN THIS INSTANCE)
(AND SO ON FOR 924 STATEMENTS)
And as far as I can see there are no other instructions in
the whole program (which has aprox. 924 statements)
Phew... Without a manual you are lost.
Ready Engineering claims to be Struthers Dunn "proficient".
PLC center Says they can service Struthers Dunn PLCs.
Magnecraft has taken over Struthers Dunn, but there is no mention of any PLCs on their website.
It was probably discontinued years (decades ?) ago. The chance that there is still someone that can help you is VERY small.
Struthers Dunn plc
I may be able to help you. Way back then I installed numerous strut hers Dunn Plc s and built test equipment an d repaired mod ules
Struthers Dunn plc question. I wish I could have seen your question when it was poste
hello
HERE THEY ARE:
LDA 024
ORC 024
STO 025
OR 001
AND 105
LDAC 057
MR 000
ANDC 105
I wish I could have seen this post when it was current. I have extencive experience with this programming format. I installed several of these controls back in the early 70's I worked very close with Struthers Dunn on several installations at Ford Motor co. I even repaired the circuit boards. They were a great co to work with
Hi all, looking to model old RR relays in PLC. Does anyone have any SPECIFIC examples on how to model a relay such as a polar relay, slow pickup...
30
HelloI need software to download the program from PLC EH-A28DRP from an old machine whose manufacturer does not exist. It may be Ladder Editor for...
27
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
202
Hello, I have a Mitsubishi FX3G 14M PLC and a E615 HMI from Mitsubishi/Beijer. I'm using GXWorks 2 to do the programming and I have no problem...
126
Hi, I'm trying to import a Rockwell/AB EDS to Beckhoff but I'm not sure how to import/install the EDS. It is a PowerFlex 525 EDS. Is there a way...
99
