STUDENT QUESTION: LADSIM Bottling Plant
Glad people on here were able to help, just a bit of advice, break down your software into manageable chunks, be aware of interlocks between sequences for example in your project filler, combiner, final pack. just build the filler and get it working then move on. One suggestion on here was not to use latches, in many situations this is almost impossible, however you could code without SET/RESET by OR output round trigger rungs then put not contacts to de-latch it. this keeps the logic on one rung.
OUT
OUT |
Yes that's correct, otherwise it stays on sometimes it's better to put the reset under the set as it is easier to debug, however it may not be convenient. Different people have different ways of doing their logic, it will make sense to them (well sometimes) but to others it may seem odd. You will see a lot of replies to posts here where people disagree on the best way, but there is a lot of experience on here so most replies to posts will have good points.
Best of luck on your assignment.
No problem.
Here:
https://www.mediafire.com/file/rbhj8g8l58hrg6f/7.llg/file
The very worst module was Electrical Machines. Virtually NONE of the notes can be used to answer ANY of the assignment questions.
The female tutor was malicious and incompetent. We're talking personality disorder levels of behaviour. Several people had similar experiences.
You cannot do this course alone. Google Physics Forums. The homework section is a life saver. A lot of students get help from there.
https://www.physicsforums.com/
Keep going. It feels great when you complete it.
No problem.
Here:
Thanks Monty, but i believe that file is for the next simulation the ICT 3 ? do you have the bottling plant one
thanks for the heads up on the electrical machines i have that todo next after this one, it has been a slog like especially with a newborn!
Legend cheers Monty
I’ve got two left mate electrical machines and microprocessor systems
I’ll be honest I’ve only engaged with a few of the tutors but all we’re accommodating who have assisted so far.
Hi everyone, I have to complete this exercise using LADSIM: http://www.plctalk.net/qanda/showthread.php?t=80080&page=4 This is how it is...
40
7,623
Hello... I am in my second week of an online Beginning .NET class. We have an assignment that is supposed to simulate a basic payroll-type...
2,276
I am a second year EET student and have a small final project that simulates a coin operated car wash. As it is our last project for the intro...
28
9,639
This is going to sound silly and fall into the category of the rack, modular thing probably but I have to ask. What specifically is the...
19
7,865
I originally was going to post this in reply to a student question but thought it might be an appropriate discussion of its own. I wonder why we...
7,099
