Jim Diesel
Hey guys,
I'm a novice programmer and looking to learn how to create logic for an analog output to control a VFD. I've taking the Logix Designer level 1 CCP 299 & Logix 5000 Programmer Certificate CCP 250. Those classes never went into logic for AI/AO control.
I need to program logic so that I have two set points for speed. I thought I could just use a Bit to control a Move function, use the Source as a INT and the Dest the Analog Output. I tried this with a project I had on my PC, I noticed when I built the logic it showed as an error. What would be the best practice on creating logic for this and I'm pretty sure I've seen RS500 logic that worked as a Bit and MOV.
