Studio 5000 CIP Error
dmag21
Mar 2023
Pennsylvania
I'm having some trouble with accepting an online edit for a program running in Studio 5000. I'm trying to change the source of a MOV function and after hitting accept pending rung edits, I get the following error:
Error: Routine 'MainProgram - S20Control_SM_Sub': CIP Error: Operation Failed.
I found an old thread that mentioned changing the CIP options in RSLinx but I have tried that and am still getting the same result.
Any help would be appreciated.
I don't know if OP will return, but in the off chance they do, can you share the status of your controller's capacity? The reason I ask is because I had a similar issue very recently, but the cause of our issue was that we were using .59 of the .6 MB available on the processor (5069-L306ERS2). We had to upgrade to the next level of processor. I don't remember the exact error, but I'm fairly certain it was similar to this if not the same error.
After adding a few tags, one of which was a string with 480 characters, I started the online edit. I only changed the tag reference on two XICs in the rung, but the program refused to accept. It would verify fine however. It took me a little bit of digging to find the memory issue.
Hi Folks! Could I use the Studio 5000 to read/monitoring Stratix 5700 parameters? Like switch temperature for example
378
CPU: 5069-L330ER v32 HMI: PV+7 10" v11 Every time the customer powers off the machine and re-applies power, the HMI gets stuck on Starting...
21,717
Hi Everyone. Not posted on here for a long time, but I am hoping someone can help me. I am doing a differential pressure calculation in a L27ERM...
294
Hi, how do I convert 2x Integer registers to a Real? The two integers are from Modbus registers that contain a floating point value, I need to...
123
What is the best way to extract the hour and minute from the register that comes from Yaskawa VFD. In studio 5000 I have a register saved as INT...
127
