Studio 5000 Licensing Question
ChaseV
Jan 2021
Minnesota
25
So we are working with a client on an update and are having problems figuring out if we need to buy a Factory Talk View Designer license or if the Studio 5000 standard edition comes with it? They currently have Factory Talk View without a license. When when researching this it looks like we need to buy a licenses. They are going from v30 to v32 and running FT View ME to running SE. Thank you in advice for any feed back.
Studio 5000
FtView ME
FtView SE
Are all different products and require separate licenses. If you have an existing license but want to upgrade versions you can do tech connect and do the upgrade. The tech connect is usually cheaper. Just depends on the amount of license the tech connect is supporting.
Just re read your post and realized you’re talking about view designer. I believe view designer was available with studio 5000 after version 27.
If your going from ME to SE then view designer is not what you need. View designer is for the panelview 5000. You should probably call your Rockwell distributor and explain to them what you’re trying to do.
Hi All, Can someone recommend the cost effective way to upgrade our existing software from v29 to v32? Here's our current software details...
4,998
I am connecting to a remote device. When attempting to upload I receive an error that states: Error: Auto_Functions: The Import was aborted due...
123
17
506
Hi Everyone. Not posted on here for a long time, but I am hoping someone can help me. I am doing a differential pressure calculation in a L27ERM...
16
397
