Studio 5000: Parse Routines (or All Tags) for a certain AOI data type
AREDA
May 2023
UK
22
Hi All,
It's a long shot, but is there a way that a routine or AOI is written to scan all routines (routine names can be fed as inputs? if required), and if it finds a specific AOI (e.g. P_ALMD or P_Alarm) and with every instance it finds, it then can map a few parameters into an array it builds?
AREDA
No.
Strings are strings, not Variants for routine names or tag names that could be passed to even a GSV. This is PLC code, not VBA.
You might be able to pull this off with Excel macros, an exported L5K file, and OPC links to the PLC. But not something native to the PLC.
You can just select the AOI in the project tree and do a cross reference. But if you want the PLC code to do the same that's a whole different thing.
Hi All,
AREDA
What is it you're trying to do?
Hi Everyone. Not posted on here for a long time, but I am hoping someone can help me. I am doing a differential pressure calculation in a L27ERM...
267
Hi, how do I convert 2x Integer registers to a Real? The two integers are from Modbus registers that contain a floating point value, I need to...
121
What is the best way to extract the hour and minute from the register that comes from Yaskawa VFD. In studio 5000 I have a register saved as INT...
125
I have an Allen Bradley temperature switch that I am trying to use in studio 5000. I am getting the message "Unable to interpret the IODD file"...
76
Hi all. I want to ask what may seem a stupid question, as I have a project to send live data to a Yeacode line printer which will print meterage...
200
