AutomationTechBrian
Studio 5000 & PF 525, Ethernet Comms, Encoder FB, Using Motor RPM as speed reference
I'm trying to figure out how to send a speed reference in RPM over the Ethernet connection between a Contrologix L71S and a Powerflex 525. I can send a speed reference in Hz to the PF 525, but I would like to be more precise and use RPM, since there is an encoder on the motor giving feedback to the VFD. The application has 4 spinning drums, with different circumference and different gear ratios. I can easily do the math in the controller to give the correct motor RPM to use as either the speed reference, or setpoint, if a PID loop is the correct technique. I just need a little help from someone who has done this before. Can I set the speed reference up as RPM? Or do I need to set up a variable set point to achieve this control? What would you do?
A note of frustration... I tried asking Rockwell (Tech Connect automation contract) but the "basic guys" had no idea what to do. They kept on telling me that I should use a scale function for my 4-20ma signal. I had to explain to them more than once that the Ethernet connection doesn't use an analog output, and that I was looking at communication tags in the PLC to use. (Wow...!) They realized this was out of their level of expertise, and tried to send me to the "Motion" guys. But they said my "Automation" contract didn't include that.
I'll keep looking for info online. Example setups are great. I'm hoping I'll stumble across one.
