Studio 5000 Watch Timer Access in Code
Sham
Sep 2019
Australia
152
Hi all,
Anyone of you knows if it is possible to access the watchdog timer directly in my code somehow? I have formed the logic of replicating the function of watchdog timer, but curious to know if it can just be done directly? I am using Control Logix.
Sham said:
Hi all,
I assume by "the watchdog timer" you mean for a Task within the project? If so, then you may access a Task WatchDog attribute using a Get System Value (GSV) instruction.
If you reference page 188 in the following document...
Logix 5000 Controllers General Instructions Reference Manual
...you will find an example of doing just that (Example 3: Getting Task Status Information...third GSV instruction).
Regards,
George
Hi all, I am wondering if there is a way to import a custom Watch Window into Studio 5000 (i.e. version 32 through 35). Essentially I am...
1,731
Hi Everyone. Not posted on here for a long time, but I am hoping someone can help me. I am doing a differential pressure calculation in a L27ERM...
357
Hi, how do I convert 2x Integer registers to a Real? The two integers are from Modbus registers that contain a floating point value, I need to...
126
What is the best way to extract the hour and minute from the register that comes from Yaskawa VFD. In studio 5000 I have a register saved as INT...
130
I have an Allen Bradley temperature switch that I am trying to use in studio 5000. I am getting the message "Unable to interpret the IODD file"...
83
