Sub $150 Panel Mount "HMC" with RTC 1 DI, 2DO?? 2 DO
theColonel26
Feb 2014
West Michigan
785
Our Mech E has a simple project where he needs a controller with an RTC, 1DI, 2DO (preferred relay) minimum. It needs a user interface so the user can change some INT values. the int values need to be Labeled as well, we can't just use a smart relay and edit the registers by address on the display. Preferred voltage is 120VAC or 12VDC.
Max price is $150
current runners are
Jazz w/ 6 digital inputs and 4 relay outputs
JZ20-J-R10
and the Delta TP04P-16TP1R if he can find a reliable source under $150
Other suggestions?
Your price point and your I/O count seem to drop by 1/3 every week.
Unless you're building hundreds of these units, buy one that you already know how to use and has the features that you want.
I bought a $12 12V DC timing relay to run the bilge pumps the other day, complete with an RTC. Combine it with actual relays for the and/or features you want, and maybe that's a solution
SIEMENS LOGO! with personalized screens
A Siemens LOGO! (It is a smart relay) with personalized screens could make what you need.
Best regards
This is a different project, and not mine to boot, just helping out our Mechanical Engineer.
Also cool that is diffinetly in the budget, I would need another time that ticks in seconds for a On off time though. I'll look around.
The other one which is alittle higher end is still going, just back burnered for the moment. After talking to a Phoenix Contact Rep we are looking to go with a ILC131 for that other project.
Best regards
hmm I'll look at it, thanks
What INT values do you need to change?
If you are adjusting something like time variables you could just buy something like a Micro 810 and use a pot (or two) on two of the inputs (configured 0-10V) to adjust the settings.
Hi guys, I am creating a sub routine and was wondering how i can trigger Bit when the sub routine first runs is it just a Open Line ? or is the...
797
Hi I hope all are doing good I have some doubt on FTV VBA coding for Drop down list. I wanted to know how to build a VBA code for Drop down list...
1,002
Context: Mitsubishi GX Developer/GT Designer 3. At the moment on our PLC's HMI (GT Designer 3), pressing any of the SCREEN buttons will navigate...
1,888
Hi, I have siemens SM1231 RTD module, the temperature I need to read is sub zero. The input is 15 bit plus sign, anyone can suggest the easiest...
2,633
