Sump Pump
dskplc
Aug 2013
New Zealand
119
Hello,
I am struggling to put these requirements in to ladder logic since I am learning on my own:
If phase "X1Sump" is selected, enable the following:
If start from LT reached, and low LS is healthy, run until stop from LT is reached.
If Lo LS is not healthy, generate LS fault.
If Hi LS is not helathy, generate LS fault.
If LT is > Hi SP, then Hi alarm.
If LT is > HiHi SP, then HiHi alarm.
Display fault message for:
Pump
LT alarms
LS alarms
If Lo LS is not healthy, and LT > Lo alarm, then fault message "Level disagreement"
Thanks for any help getting me started.
I am controlling a very tight window in a 8 foot sump. My low level to keep from cavitating the pump is 44” and my high level is 55”. The problem...
2,072
I have a pretty simple question I believe on setting up a sump pump control box. I have a sump pump that is 120/1 with a thermal overload...
3,330
Hello all, I am very new to plc programming and have been watching videos, and reading up on them. I have a beginners class Mid March. I have a...
6,803
Hi everyone, Okay here is my question,Im trying to write a program with AB logix ladder.I want to control a sump pump at work with a slc500.I...
2,845
Hi, I have a basic sump tank with a hi level float and a lo level float. I want to control the level of this sump using a pump that is pumping...
3,245
