Switch question
faehigkeit1
Jul 2007
virginia
77
Hello everybody, I am trying to find a switch that activates seperate contacts depending on which way the roller lever is moved left or right. This would eliminate having to mount two switches.
Thanks for any help
Dean
I think what you are after is a three position selector switch either maintained or spring return.
Some suppliers can't figure anything out if you don't give them a part number.
How about this from Eaton / Cutler Hammer:
<Disclaimer, I work for an Eaton Distributor>
Hi everyone, I am currently using a Panelview plus 7 standard and i have a question regarding switching languages in factory talk studios. Is it...
2,234
I have a operating 7026 managed switch and will be adding 16 drives which will require an additional switch. Can I purchased a unmanaged switch...
5,869
I am currently looking for a solution to provide proving status of a DC motor. The DC motor I have draws maybe .4 to .5 DC amps. very small. I...
2,527
I have an AB 1100 running a program witch controls 7 or so actuators. I would like to add status proving devices to the system. I was looking...
1,584
New to PLC programming, experienced in a few other computer languages. I am having trouble understanding why a normally closed safety switch is...
2,846
