Switch Status in RSlogix 5000 ?
Miguel554
Jun 2019
Arizona
So I would like to check the firmware on a stratix 5700 switch. Is there a switch status function in RSlogix 5000 that tells you the status and firmware of that switch? I heard it would be in the I/O tree.
It would have to be added to the I/O tree (which I think it should only be added to a single processor). Simpler would be to just pull up the web page for the switch.
To pull up the webpage I believe I need the IP address. What is the easiest way to find out the IP address for the switch? Would it be hooking my laptop to port one and running an ipconfig? The real issue I'm having is the Stratix 5700 switch is flashing red on the EIP MOD but no real issue that I know of. I believe to fix this is to upgrade the firmware.
It could be any number of issues causing the EIP MOD light to flash red. You really need to check the syslog on the switch to see what is causing it. Easiest way to do this is by connecting to the web server on the switch, to do this need the IP address of the switch and type it into your web browser.
Chances are the switch has a management IP address on the same network as your PLC. Set your PC up as if you were going to connect to the PLC, plug into the switch and then run an IP scan on the network. Advanced IP Scanner is a free utility you can use for this.
Hopefully you should be able to see your switch show up in the list of scanned IP's.
We have many CISCO and STRATIX switches in our process network. The Stratix switches have AOPs that enables us to use our Rockwell PLCs to gather...
2,237
Hello PLCS hombres! I have a question according to input status message with CAN. So i want to send a limit switch input status through CAN. I...
1,240
Hello everyone Iam working on washing machine which washing onion and water level is very critical for the process. The machine used IFM 121 for...
97
Hello, I have a A.B Compact logix communicating with two fanuc robots via ethernet. The plc also communicates to an automation direct hmi screen...
403
Looking for a supplier of Layer 3 Network Switches DIN RAIL MOUNT, in Alabama, In the UK we would use Typically in the UK we would use...
201
