Symax instruction help req
milindpatel
Sep 2010
baroda
Hi Everyone,
I am converting one of the SYMAX 400 Processor to AB. I want to know about the function of one of the instruction in the attached pic. I tried to find out the docs for Instruction Manual for SQD-SY/MAX processors but nothing available.
This appears to be one of several Special (SPEC) instructions supported by the SY/MAX Model 400 processors...
LET is a Data Transfer instruction which transfers data from one register to another. BIN refers to the conversion described above. SPEC simply tells us this is a Special instruction.
In the example above, S10 is a Binary Coded Decimal value and is being converted to a Binary value and stored in S20.
"AB" is quite a generic reference to a large family of Allen Bradley controllers. But aside from all that, may I ask at least which controller architecture you are converting to (Logix 500 or 5000)? It may matter "if" you require further assistance with handling BCD conversion in the "AB" World.
Regards,
George
Hi GEO.. Thanks for the reply. But what does that ^16383 mean...? I do not get that part. I am working on L73 Controllers using STUDIO 5000...
Regards,
George
Hi, I think in the example, S20 is the BCD value, which is being converted to binary and the binary value is held in the register S10....
Andy
Fairly sure this is like Bitwise code....
So what you have is LET register S0165 (BCD) = S0001 AND 16383
(The ^ symbol in your code means AND)
So it’s bitwise AND, where you multiply the bits in each column to make a resultant 16 bit word. In your example you are masking the last two columns.
Remember everything is in binary
Register S0001 let’s say might equal 1011 1010 1111 0001 (just as an example)
So you AND this to the binary value of 16383 which is 0011 1111 1111 1111
The resultant word is the product of each column multiplied so:
1011 1010 1111 0001
And
0011 1111 1111 1111
Equals
0011 1010 1111 0001
This final value would then be converted to BCD and stored in register S0165
Hope that helps
Andy
Hey. So, we are upgrading an old Symax PLC to CLX and I've come across a "SHORT" instruction in one of the ladder rungs. I've downloaded the...
3,235
Hello everybody! I am working on upgrading an exisiting PLC system comprising of a Symax Model 300 PLC. I am replacing it with an Allen-Bradley...
6,260
Square-D Symax SFI-324 I have used the SFI-510 card for many projects, but I came across a SFI-324. Does anyone have ant tech info on it?
85
I have a few program files that I need to convert into a printable format. We don't have a dot matrix printer available to us. Would anyone be...
747
I have been tasked to upgrade some SquareD PLCs at our plant. I have done several of these upgrades without any issues. However, I have now met my...
2,453
