Symax module addressing
recabite
Dec 2006
Beechworth
22
Greetings all.
At my work we use symax 400 to control 2 pieces of equipment and we have a spare cpu and cards which I have put these all together and can view the CPU with plc software. The problem i have is addressing or even seeing the cards in the CPU. The CPU is a model 400 and the cards are a 32 input 24vdv RIM 331, a 32 output 24vdc ROM 441 and a high speed counter card RIM 131. Can anyone tell me what addressing i will need and do i need to put supply to cards befor the will be seen in rack addressing PLS HELP [email protected] cards are in order of Rim slot2 rom slot 3 and hsc slot 4
Although not required, each slot should be assigned at least as many registers as each card uses.
In your case you could use:
slot 1 beginning ---- ending ----
slot 2 beginning 1001 ending 1002
slot 3 beginning 1003 ending 1004
slot 4 beginning 1005 ending 1020
I suggest you go to www.squared.com and get a copy of the 8010SFW374 software programming guide.
Square-D Symax SFI-324 I have used the SFI-510 card for many projects, but I came across a SFI-324. Does anyone have ant tech info on it?
80
I have a few program files that I need to convert into a printable format. We don't have a dot matrix printer available to us. Would anyone be...
744
I have been tasked to upgrade some SquareD PLCs at our plant. I have done several of these upgrades without any issues. However, I have now met my...
2,447
Hello all and thanks in advance for any help on this. I am working with a symax 400 processor and i'm trying to wrap my head around the...
1,022
Anyone know where I can get a replacement key for this? I know that it said "01115E" or "0I115E" on the side of the key. It was brass. Not much...
999
