SYNCH LINK Fault of Rockwell
md.abdullah
Sep 2011
motihari
168
Hello frnds
i have Rockwell system L63 with four Chassis A,B,C and D
with controlnet network.i have some SOE module installed in four chassis and four synch link module in ring network.now problem is in chassis B synch link module is faulted(steady red)rest all are healthy working properly.i have read manuals of synch link there it say replace the module.but when i change Chassis A synch link to B it again here shows faulted while B is ok in A chassis.i have gone through all module configuration as ok mudle as B chassis....any solution frnds..
I have checked a,b,c and d chassis synch link module interchange.this is not possible when every module is working properly but in B chassis any Synch link module goes faulted.while i have given same configuration to the B chassis module..any help
I have an application that's in initial development. Two sets of 5700 racks, 4 axes each, separate power supplies, separate cabinets The two...
635
Its that silly time of year again I am tasked with making sure all important PLC clocks get updated for Daylight Savings Time. For the most part...
6,676
Hi. We are using a kinetix 5500 to control an eccentric conveyor motor. We are experiencing sporadic and intermittent occurrences of a "Control...
5,835
I have 2 GuardMaster 440C-CR30 Safety relays in the same panel. One of them sporadically faults (approx. 15 times per 8 hour period) with the...
5,501
I am working on an old plastic extruder and I need to synch two chilled rollers of different diameters together. On roller is ~20" and the other...
2,699
