Tag update not fast enough
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Hello all. I have a 5069-L306ERMS2 that is interfaced with an ABB IRC palletizing robot. I am having trouble metering cases to the pick point (controlled by PLC) when it involves a single case. What is happening is, the robot tells the PLC how many cases it requires for each pick. For cases of 2 or more, there is no issue. When it is a single case, the PLC register doesn't update fast enough and the conveyor allows an extra case through. All attempts I have made so far haven't worked because it throws a wrench into the sequencers. All of the tasks are scanned continuously, 500mS. I am thinking I should create a small routine that will update this register more predictably and quicker. What I can't decide is, should I make this event triggered (as soon as the robot sends), or periodic. I would sure appreciate some feedback on this. Thx
You could create a continuous routine, or one that is trigger based.
I have a routine that is scanned at 5ms to pick up a power failure before the VFDs go under-voltage. This happens in 1 or 2/60th of a second, so I know it can scan very fast when required.
500ms is pretty slow, maybe okay for process control.
It sounds like you chose periodic and set it to 5ms?
Hello to the community, I am new to Rockwell and I have a small problem with a PvP1000(2711P). Some buttons in the same screen are not...
2,352
Hi, Looking for some advice regarding the tag update setting in Panelview Plus 7 terminals. We’re starting to install these as upgrades from old...
3,111
In the process of upgrading a PLC-5 to a CLX, I need to update all my tags in the Crimson database. I don't see an export/import feature for...
1,776
Hi All, I am creating a new version of a previous stand alone InTouch application. A number of the tags names are changing. Is there a way or...
1,163
If I have a tag that is updated from one of several different tags, and each of those several different tags are, in turn, reliant on other tags...
1,487
