TAGS- from TIA portal v11 to wincc V7 sp3
Jun 2012
Saudi Arabia
Dear All,
my project has 5 PLC (S7-1200) and I programed them by TIA PORTAL V11.
and I want to connect them by Ether net to SCADA (WINCC EXPLORAL V7 SP3).
how can I take the tags from TIA to (WINCC EXPLORAL V7 SP3)?
B.R.
Hi, Is there an easy way to limit the input tag by using min and max tags from the PLC? Thanks
1,286
Hello guys, I use Tia Portal V16. What is the best way to change the indexed HMI tags when I change the format of an Udt in my plc program...
1,314
In TIA Portal, Is it possible to have all HMI tags linked automatically to the PLC or do you have to go through each HMI tag individually and link...
4,622
I have a small modification that I want to make to a program in an S7-1500 using TIA portal V14 SP1. I have a global data block containing some...
3,792
Hi, Sometimes I find myself in a situation where I have some scattered variables in datablocks that I want to place under a struct to get a better...
1,992
