tank formulas?
showshocka
Mar 2011
USA
510
Can anyone help me out with the "TRUE RIGHT" formula of finding how much a cylindrical tank will hold in h20 that can be converted over to lbs? i see so many other ways to do it. i'm sure it's only one RIGHT FORMULA though. I used one yesterday and can out right bUt will not work for another tank, a different size.
It's an easy calculation if the cylindrical tank is standing on end. Then the formula for volume is PI * r^2 * h where r is the radius of the tank and h is the height of water in the tank. Water weighs 8.3 pounds per gallon and there are 231 cubic inches of water in one gallon, so calculate the volume of water in the tank cubic inches, divide that by 231 to get gallons and multiply the result by 8.3 to get pounds.
If the tank is mounted horizontally, the calculation is more complicated. It gets even worse for a horizontal tank with spherical ends.
In what units will i use when i get the answer for this?
Depends on what units you're using for r and h. Whatever units you use, they need to be the same for both r and h.
Ex. If the tank is 12" wide and 24" high then its:
V = 3.14159 * (6" ^ 2) * 24"
= 2,714 cubic inches
or
For a tank that is 1 foot wide and 2 feet high:
V = 3.14159 * (0.5ft ^ 2) * 2ft
= 1.57 cubic feet
I apologize for offending anyone with my comment. I was just so astonished that we get such a wide variety of questions here on PLCTalk.net.
Thought it was lbs.
I don't think your comment was offensive. I had a similar response when I saw the question. If you are looking for pounds wouldn't your units be lbs? Or maybe the OP meant something else.
RTA, It seems kind of self-evident, but then I had a pretty good 5th grade math teacher. I think that is when I first heard about the idea of "units".
I want to measure the tank level and get the sensor output to the PLC. Below are the details : Tank Height =0 - 3m, the sensor is stalled 0,2m...
639
Does anyone have RSLogix 5000 ladder diagram program of tank leveling (factory IO). Fill valve, discharge valve, set point, level, etc? I looked...
157
I seem to remember a number of posts regarding calculation the actual level or volume in a horizontal tank, here is the formula written in ST...
1,546
I'm coming from a background of PLC ladderlogic/rockwell products. I am new to blocks. Can you point me in right right direction? What I would...
1,563
