TCP Socket Client Error 16#11
AndyEM
Aug 2016
Manchester
I am using 1756-L71 and 1756-EN2TR to communicate with ABB PickMaster, robot application running on industrial PC, via TCP Socket Client.
I create the socket and open the connection with no errors but when I write some data using WriteSocket message I get an error code of 16#11 (extended error 16#00).
Looked through various documents and Rockwell knowledge base and cannot find this error code defined.
Anybody else had this error code or have any ideas?
I don't know about the error but I would use Wireshark between the 2 devices to see what's happening.
Thanks for the advice Epy,
I will try Rockwell once I am back within my support hours in the morning and if I do not get any joy there I will try as you suggest.
It is a weird one because the software I am communicating with gets the message and responds correctly even though I get an error on the write.
Hi Everybody, newbie here with PLCs, using a B&R plc. I'm playing with a printer and its tcp socket communication. Connection works fine if...
184
Hi all, I have two questions I am hoping someone might have some information on. 1. I remembered reading somewhere on this forum that you could...
207
Hello, I'm trying to setup a TCP connection from a Compactlogix 5069-L306ER to a TDI checkweigher to receive real-time weight data of the...
344
I would like to communication with application installation in my printer server via TCP port 5450. i.e ., 71.16.40.200:5450 . How can i write...
440
I'm trying to set up a TCP Socket connection between a CompactLogix 1769-L16 and a printer that can receive external data through a TCP socket. I...
3,397
