td 400c communication cable..
Nelliyan
Sep 2011
90
Hi to all,
i am using s7 200 in my machine along with td400c(Hmi)..using ppi cable i can communicate between pc & cpu... Now the problem is i dont know the "cable configuration" for communicating the cpu and hmi...pls send any link or manual tht can help to prepare the cable...
(Db9- 2 side male)
Thanks in Advance...
Thanks for the reply,,
Now it s possible for me to communicate between the hmi(mp 177 b) and My pc with out using the ppi cable...reason my ppi cable got damaged...so pls guide in this issue
Thanks in Advance
Hi, Sorry for my bad English The 400C show 037:Battery low so we power off the drive then we pull out the battery and found the new one. After 5...
1,248
Well it looks like this thing is pretty limited. I think they are artificially handicapping the logic so they don't erode their other controller...
1,950
Hi, I want to control a variable from the td. But i want to control from the td a variable set in a range of 0 to 1000. It´s posible to do...
2,583
Hi all. I have a Modbus ProSoft module in my setup with a capability of 30 clients (0-29), which I'm trying to monitor the Ethernet Connection...
31
Hi folks, I have a Controllogix in communication with a zigbee coordinator using Logix AIO for modbus tcp. This zigbee coordinator have 3 slaves...
161
