Team viewer help
stu
Aug 2005
England
783
Hi guys I have been told to use team viewer to connect to a plc off site ? I have downloaded the software onto the laptop and tested using my phone the laptop was on WiFi and my phone was 4g which I can control every thing but now is the issue if I plug the lan into the plc I loose WiFi connection how can I use both ??
I hope you can help
Thanks stu
I think that is going to be a problem specific to your laptop. Is the LAN connection in the same network as the wifi? Is the LAN set up for DHCP?
Is the LAN set for Static or DHCP? I don't think it matters as long as the LAN and Wifi are not getting set to the same network. The next step I would take is to exercise some Google Fu on your problem with the specifics of your laptop (make/model/year)...
From Google
  1. Open Network and Sharing Centre.
  2. Go to change Adapter Settings.
  3. Goto properties of Local Area Network.
  4. Click on Internet Protocol version 4 and go to it's properties.
  5. Click on Advanced
  6. You will see a block checked there by the name of "Automatic Metric".
  7. Uncheck it and then enter 2 in that section.
  8. Now, Do the same for the wireless network but enter 1.
Save the setting and you'll be able to use wifi even when your ethernet cable is connected to the LAN.
Give feedback if it works
Funny thing is it's a Hp laptop , I have done some Google -Fu and mfound that is may work ,im going to try tomorrow thanks ,I think is press F10 on the start up will get me into the bios?
Hi all, i have an application in which i need to read the water level in a 1 1/2" diameter tube that is 24 in. tall. the sensor will be mounted...
27
1,975
Hello, We have a startup valve, that has to open on startup etc. We also want to know the flowrate throughe valve. They told me that in previous...
17
2,749
Hi; We installed an orifice plate type steam flow transmitter which configured to give 4-20mA signal correspond to 0-9ton. I given that signal...
24
5,614
The IAPWS-IF97 steam table is used as a measuring standard for the correlation between steam temperature and pressure. The calculation formula(s)...
1,710
Good day Gents, Does atmospheric pressure have an influence of a boiler steam pressure.
31
8,609
