Technology levels
Buy 07kt92 / 07kt93
My name is Fábio. I work for a graphic company in Brazil. I am writing because I am looking for PLC ABB 07KT92 e 07KT93 to buy. However, it isn´t easy, for they are discontinued. Please, if somebody has or knows where I can find them I will be very happy
Just a thought Fabio... Maybe you should stop reopening many-year-old threads to post the same comment.
Try Google MAYBE SOMETHING WILL SHOW UP.
stevez said:
This is for cmedico.The same as level 6 but has to pass a FDA inspection.
Well, folks. It doesn´t matter if it´s an old or new comment. The point is: I am needing some help to find these PLC´s for both are discontinued products. If you can help me, I thank you...however, if you can´t help me, please, don´t feed me up.
I think the comments have been more that you should start your own new thread instead of hijacking a thread that is on a totally different subject...
My first ideas are to try a Google/Froogle search and to try eBay. Also if you start a new thread then with a relevant subject you'll get a lot more people to look and that will increase your chances of finding someone who can help you.
FABIO
I responded in one of the other threads that you did this, if what you want is not related to the thread you will probably not get an answer.
AS I suggested, start your own thread. If/when you do you will get many more appropriate responses.
Actually Fabio, it DOES matter.
The content of the OLD TREAD actually is a distraction that diverts attention from YOUR post. Old threads die and fall by the wayside for a reason: lack of interest. Dredging them back up clogs up the CURRENT board. Readers that find your exact same post on several old threads don't consider your credibility to be too positive. You make yourself look foolish (no offense intended). I'm trying to help you NOT do that.
The way to get the best response from THIS forum would be to start a new thread of you own.
I'm not very familiar with HSQ RTUs so I need some help if anyone can give it. I have an RTU that keeps cycling off to where I have to cycle the...
524
when controlling a closed loop stepper motor with a PLC,the PLC doesn't know if the target position is reached or not unless the driver it selfe...
992
Hi I have a 1211C Cpu and a CU250S-vector. I tried to make positioning object... But I can't get it to work... Doe à G120 actually can do TO? Or...
20
3,043
Hi guys.Can somebody explain me or give me a practical example what is the fail-safe technology/signals . For what i read it is force plant into...
2,553
Good Afternoon , We had a rough summer with power outages , and I am always looking for a stable UPS system that would " ride us through" an...
1,770
